Brodie
My commuter is a Scion Xa with an Auto. My 305 is an F'n rocket!!!!!!!!
NateInChandler said:14010201 305 80-85 2 bolt main
Kyle Strong (in his signature) said:It's growing faster than a stiffie on a 14 year old!
Craig Artzner said:Sorry for the hijack, but I just gotta ask...what's up with the signature? It pretty much gives me the creeps...
..adding a 4.11 ratio axle makes a world of difference,and actually improves gas mileage in many cases,it lets the motor work less hard,and in its power band..
gibby2268 said:My DD is a 99 Nissan 2wd truck, with a fourbanger and auto, so it makes a 305 feel like a big block!![]()
diesel4me said:The reason 305's and 307's got a bad rap in my opinion,is the fact many of them had soft cam lobes factory,and 90% of them are limping around on 7 cylinders (or less!),and not reaching their full potential,due to the valves not opening all the way!..plus in the case of the 307,it's short stroke does not make it a very good low end torque producer,but it excels at high rpms..
Adding a new cam ground for off-road and low RPM towing will wake these motors right up..adding a SMALL CFM 4 bbl carb will too..(despite GM using a 800 CFM Q-jet,they just dont need that big a carb,IMO--)...
Many of these motors were put in heavy full sized trucks and cars,with ridiculously high axle ratio's like 3.08's and 2.73's,2.56's,etc..so its no wonder they are called "dogs" or "turds"..you'd be a slug too under those conditions!...adding a 4.11 ratio axle makes a world of difference,and actually improves gas mileage in many cases,it lets the motor work less hard,and in its power band..
I had an '86 305 from a van in my 79 G10--I thought it was pretty peppy for a 305--I think it might mave been similar to the "high output" 305's used in Camaros and Monte Carlo SS's,that had higher compression..I have driven a few older 2 bbl 305's that were VERY anemic however..
I think the 305 is a good comprimise between fuel economy,and adequate performance for daily street use...yeah,it aint no 454 at the dragstrip,but you can pass a lot more gas stations with it!...and all that big block power CAN bust things up pretty easily too--you can beat a truck with a 305 a lot harder,and not hurt anything...![]()
I had an article that I found (in Hot Rod Engine Masters I think) that showed a build up of a 305 and their power potential. It mentioned the fact that everyone hates this block but you could still make decent power out of them. I'll try to find the mag and post a link to it. I don't know if anyone would spend the money to do a nice build of one, but if I had some of the extra parts for one I might try it. It would be a cool experiment, and mabey an acceptable back-up engine if you had the parts for a quick build.Kyle Strong said:I've also heard bad things about those motors...I wonder what makes these motors poor performers? Bad head design? Weak castings/bad oil passages? I know small displacement ford engines are pretty good (289-302), but I never hear anything good about 305-307's.
cheyennek20 said:I had an article that I found (in Hot Rod Engine Masters I think) that showed a build up of a 305 and their power potential. It mentioned the fact that everyone hates this block but you could still make decent power out of them. I'll try to find the mag and post a link to it. I don't know if anyone would spend the money to do a nice build of one, but if I had some of the extra parts for one I might try it. It would be a cool experiment, and mabey an acceptable back-up engine if you had the parts for a quick build.![]()
NoReGrEtS said:Just got done reading this article then saw this thread. Weird
http://www.popularhotrodding.com/enginemasters/articles/chevrolet/0667_phrs_305_chevy_engine_blocks/
I think that's awsome!
