y5mgisi
1 ton status
Between 1/2 ton and 3/4 and all years? If not, what are the differences?
Some weird info going on here.......
There are no 10-bolts that came from the factory with external style lock-outs, or shaft length differences. You would be talking about Dana 44's as some had external hubs and the inner shaft lengths were different than the 10-bolts.
I never heard reference to the 8.6" 10-bolt until at least the late-90's or early 2000's so well after the last 10-bolt front axle was produced. However the 89.5 model year could very well be the time they switched as all factory '90-'91 K5 and Sub's I have seen came with 30-spline front shafts, but I have heard both ways on '89's.
Basically you need to verify you currently have 30-spline shafts and when you buy used actually count the splines and check the length. I remember years ago trying to order a new set of factory 30-spline shafts for my 10-bolt and a large and well known company kept sending me D44 shafts. I finally had to send them a picture of the shafts side by side showing the differences. Also with a 24 year old truck you never know if the axles have been swapped out at some time unless you have had the truck forever.
