Done a lot of research on the boards and found the general consensus is to swap to manual lockers. My problem is that finances are unusually tight at the moment for several reasons and until I have the funds for new lockers, my only option is to attempt to figure out if I can get these going for a little while longer.
What's going on is while in 2wd, it seems that one or both sides is attempting to engage. Right before a complete stop, I can hear a slight grind then when almost completely stopped, I feel and hear them try to grab. After a 5 or 10 mile run, the hubs are hot. Not too hot to touch but still warmer than normal. I've confirmed the heat is not the brakes or wheel bearings. There are no broken pieces in the hub and the bearings are snug and full of grease. The hubs have just a film of grease on the splined sections. Can anyone point me to what component of the auto hub should be related to it attempting to engage without command?
