Are Delphi injectors any good?
protechk5
VA
Some guy is selling a set of brand new military surplus 6.2/6.5 N/A Delphi short injectors, p#6783802, date code CXT, for $150 shipped. Sounds like a good deal to me. They are N/A and I am putting a turbo on my truck right now, but i dont think it will make a difference with my stock IP, will it? My injectors are pushing close to 90,000 miles and my engine seems to run prefect, but i want the short ones to make my turbo install easier.
Delphi are a OEM Factory Injector
150.00 for surplus injectors whether new or not is high in my opinion however to each his own and probably the going rate.
If you currently have the "Long" injectors on your truck you may have to tweak the injection lines to make the short ones fit. Be very careful not to bend them as you will screw them up. Some downward tension on the lines is ok what I have done is to use just enough pressure to get positive thread engagement then tighten them down using the nut while not putting any pressure anywhere on the line without ill effect.
Make sure that you are using the proper thread, Early 6.2 injectors are Coarse Thread and will only fit on the first two year models 82-83.
If you arent experiencing any mis-fires etc right now then you will probably not see any difference at all. On IDI motors the injectors either work or dont.
