What I've done on many GM trucks I owned,was to ditch the stupid metal pipe GM uses to route the wires containing the fusible links that is way too close to the red hot exhaust manifolds,remove those wires from the starter terminal where the positive cable is attached,and instead,run them right to the positive battery terminal,and route them away from any heat or places they may be damaged,up on the inner fender..that plastic flexible conduit stuff for house wiring works well to protect the wires...if they are too short to reach the battery,I just cut the ring connectors off and splice some more 8 gauge wire onto them to allow them to reach......and bolt them to the battery cable bolt...................................................................................................................................................................................................This way,the only wires left going to the starter are the positive battery cable,and the thick purple wire that makes it crank when you turn the key to start....GM used to run the wires like that up until 1969 or so on all their trucks,I dont know why they thought running them in metal conduit an inch away from the exhaust manifold wouldn't bake them,and lead to troubles...not to mention being a big pain to FIX the fusible links...I swear the "engineers" must have a vendetta against the mechanics and people like us who insist on doing their own repairs sometimes...like it was done on purpose!..."lets take something that works FINE,and make it "problematic"...to increase profits!..
