1-8-4-3-6-5-7-2
Registered Member
Here are some pics of the spark plugs from my recently purchased 1994 K1500 with a 350 TBI motor.
Things I know about the truck...
1. The timing is about 10* off from where it should be (It should be at 0*)
2. The truck runs hotter than it should
3. A very noticeable erratic miss at idle
4. A small amount of continuous white smoke from the tailpipe at idle, engine warm or cold
5. The plug wires were trash and the distributor cap had a lot of corrosion inside on the terminals.
Do these plugs indicate any problems, or do they look bad from neglect?
The first pic is cylinders 2,4,6, and 8. The second pic is numbers 1,3,5, and 7. The third pic is a close up shot of numbers 2 and 6.
