Are my vacuum readings correct?
wazzabie
Washington State
I have a 78 K5 with federal emisions -350 chevy
here are my rpms settings
fast idle - 1600 rpms
idle rpm - 700 rpms
my vacuum at fast idle is 20
my vacuum at low idle is 13
Are my vacuum settings correct?\
Also timming is at 8 btc
Also I did not disconnect the hose to the vacuum advance when I took the readings or adjusted the idle mixture screws.
Yeah it's weird that you have higher vacuum at 1600 than at Idle, but you have decent vacuum at idle.
idle rpm - 700 rpms
I do have to ask this....
you do have it hooked up below the throttle plate correct? not a ported source on the carb?
I had it hooked up to the vacuum that goes out to the termal sensor that opperates the air duct in the intake.
Anyways I moved it to so now it sources from the vacuum for the tranny modulator.
The new readings at low idle are 14. It is not quite at 15. Maybe 14.5 at times. Is this ok?
Also at low idle the rpms can change bu as much asa 25 rpms up or down. Is this ok?
a ported source is any port above the throttle plate...
thats why your readings where reversed... a ported source reads the opposite of manifold vacuum...
Connect it anywhere on the intake manifold or on the base plate for the carb for accurate readings. A timed port will be above the carburator throttle plates, dont use them. Its not bad, but it wont give you correct vacuum readings.
I just realized the other post came after these responses, it explains the reversed readings.
I thought these numbers were after he connected to the tranny vacuum source.:doah:
I always have to remind myself that the things oldschool gearheads like us take for granted, may not be as obvious to someone starting out...
