Thanks for all your interest out there, here are the numbers, dyno tested on a superflow 901, 300 RPM per second, 475 CID, 9.2 compression, Isky 280 mega cam, hyd flat tappet, ported 236 heads, 2.125 Int, 1.880 Exhaust, performer RPM intake quick fuel ss 830. 501.6 HP @ 5100, Peak 541.4 HP @ 5400 RPM, 532.3 HP @ 5700 RPM. Torque: 575.2 @ 3800 RPM, peak 583.3 @ 4000 RPM, 526 @ 5400 RPM. Harold Bettes will be submitting a full report on this project, covering the the engine build, and also the calibrations on the conservative 901 dyno. Sorry I didnt have more time to test different intakes, I feel the results were ok, and I dont think Iam setting the world on fire with this one, its just ok. Thanks Mark
