Are the Leafs suppost to look like this? Pics
katugly
Goddard, Kansas
As the title says.
The rears look fine it’s just the fronts look goofy to me for some reason.
Ok just thought it was weird they had a negative arch in them and I had honestly never seen any others to compare.
Pretty much all Blazers and I believe 1/2 ton trucks have reverse arced springs. At least until the saggy butt syndrome finally flips them.
mine are flat..... like a 2x4 and the p/o put coil over shocks on the front ... rode like a buckboard when i got it
My stock springs looked like that. When I put a 4in. lift on it, I got 6 in. of lift. I'm waiting for them to settle (or does anyone have a winch and bumper cheap?)
I would scoop some springs from a Cheyenne or Scottsdale model truck. They will have the front 3 leaf packs that haven't negatively arched with time.
they are arched like that from being wore out. you can't flip the main leaf anyway, the eyes would be on the wrong side.
Mine used to be flat, went flexing around a few months ago and now they have negative arch's to them. :rotfl:
didn't come like that but with time it happens to alot of trucks, not much to worry about except for the negative lift ha
So could I flip the spring to achieve a cheap front lift?
Oh heck no! You could potentially flip the second leaf, but not the main. I expect that with the weight off of them the arch wouldn't be negative anyway. So you might flip the second leaf and end up with the truck lower :doah:But there's no reason you can't add leafs to the pack for a little lift. When you're adding them in the length isn't even that critical. You can use stuff from almost any make.
You are wrong about that. The stock front springs on blazers are made like that from the factory.
ya, i said normal in the first post, so what is more correct then that.
wtf are we arguing about this for? stock, wore out junk front springs.
