Are There Any Four Inch Lift Sets That Comes In A Complete Set Front Amd Back?
lift kit stuff for 8 lug = good luck buddy .
i would do a 3" body and 1" coil spacer to get the 4" lift if you really need it . and i dont really do body lifts .
some guy on other forums i have read over the years play with a mix of 73-87 and 88-98 body style lift parts and some tweeking with all that just to get 3" lift .
I don't know if anyone makes the parts, but you could space the front crossmember down 4" fairly easy. Then 4" blocks in the rear.
You forget the crossmember and the a arms also bolt on the side of the frame, not so easy to put a block.
I have a set of airbags that go inside the coils, supposed to be good for 2"
Never did use them, ended up converting to 4wd
You can re-drill bolts in the side of the frame along the upper a-arm and add reinforcements where needed. But I'm a mechanical engineer that loves solving challenges like that. It would require some fabrication.
Years ago places like J.C. Whitney sold 2WD lift kits that consisted of longer coil springs and a ball joint spacer up front..but I think they were only good for about 2" of lift..
If I recall it uses 3/4 ton a arms & ball joints. I imagine a little creativity can make 8 lug spindles work. Been thinking about this for my 3/4 ton 8 lug 'burb after I get my 4x4 up.
