Are There Much Difference Between a Half Ton And 2 Quarter Suburbans From 1973 to 1991?
Sounds like you assume that pulling is all about the engine? 3/4 will have larger rear axle, lower gears, bigger brakes, stiffer springs. Overall much better for towing.
