I’m in the middle of a shackle flip with these used 56” springs I bought. Under the suburban’s own weight, these 7+1 3/4 ton springs are flat. Well they have 3/4” of arch. The top leaf is a little wavy like it’s fatigued at the ends. See pics. The lift height seems about right. Just not sure if I should continue or find better springs. The RC ones never changed shape (super stiff) and my ORD fronts got a little wavy pretty quickly (ORD said it’s normal). So I’m not sure what’s acceptable with stock springs.
Side note: my rough country 4” springs are ~58” along the arch. What are your thoughts on replacing the top leaves of the stock spring with the arched RC one? swapping the shackle hangers left to right would accommodate the extra 2 inches exactly. The leaves are both about 5/16” thick…just not sure if the RC will like laying flatter or how much it’ll affect the ride. I’m not opposed to a slight bump in lift either. I planned on using a zero rate anyway.
String added for reference
Note the main leaf wave
Free hanging
Free hanging
