Never Satisfied
These spindle nut lock washers are pretty mangled up. I don't know what the previous guy did to them, but the "teeth" don't line up at all with the spots on the nut. Can I still buy these? If so, where?
Stage 8 makes an improved aftermarket version that won't loosen . 56.95 at Summit .......... 129.95 at Scout parts![]()
anyone know if they make these for a 14 bolt?
Here ya go:to other options people.
newer 14ff use a thinker nut and a square stock key and lock snap ring. these can be swaped on like it was there from factory. just go junk yard hunting.
also the dana 60 and 14ff use the same spindle size / threads so you can swap on a set of dana 60 nuts and lock washer. these can be had at the junk piles or new cheeply.
also the benifit to this one is 1 socket for both axles if you are running a 60 front.![]()
