Are these the Correct spacers?
well, you need to get 9/16 studs to match your current ones. otherwise you'll be buying new lug nuts....search for some with diff studs. the 14MM ones will end up costing you more in the long run since you gotta buy 32 more lug nuts in a 14mm flavor.
The first ones will work. The add says they come with lug nuts so those would by the 14mm X 1.5 and you would bolt the spacer to your studs with your existing lug nuts.
If you buy 2 sets for front and rear it wont be an issue but if you are only running on one axle then do not mix up the lug nuts.
Do not buy those hub centric ones. The pilot hole is too small to work on our axles (assuming you are running a FF rear)
Dik
Ok well I would have to buy new lug nuts anyways cause the ones i have now are long shank type. Maybe it will just be easier to get rid of these rims and buy some normal 16.5 rims to put my tires on. Or just buy new 17 inch tires for my current rims.
you need 9/16 stud ones. plane and simple. there is a member here who just got screwd by this.
thay are special small hex nuts to fit in the holes. stock wont fit even with thin chrome wall socket. and just keep it what it is. 9/16 to 9/16 and 14mm to 14mm. its much easyer in the end.
Ya like I said I am just going to either sell or trade these 5 12 bolt H1 rims for factory 16.5 rims so I will not need the spacers. Seems to be the easiest way for a person like me that knows nothing about these types of things.
