dbreid
EDIT: See post #16 for the final answer!
OK,
This is sort of a continuation of a previous post, but I need to start clean, so folks don't have to wade through so much...
Here's the previous post:
http://coloradok5.com/forums/showthread.php?t=237195
1.) Alt seemed bad (doesn't matter if it was true, this was what I thought). Truck has Twin brand new Yellow Tops, and a working isolator. I am leaving one isolated, and only working with the main battery.
2.) Bought new 94A 12si alternator at NAPA (reman).
3.) While installing it, I accidentally grounded the live red charging "post" on the back. It arced, and I blew a fusible link. That saga is here: http://coloradok5.com/forums/showthread.php?t=237244&highlight=accidentally
4.) I fixed the fusible link thanks to help on here, and everything seemed to be back to normal. Truck starts up and runs fine....
5.) While I was at it, I ran a brand new ground wire to the block. Using one of the bolts in the front of the block which holds the alternator/air pump bracket.
But now I believe I might be back to square 1!
Here's what I know:
A.) With the truck OFF, I get just under 12V across the posts of the battery, using a good Multimeter. It fluctuates a bit
B.) With the truck running, I get Slightly more, but never over 13V. I know I am aiming for 13.8V.
C.) When I measure the voltage of the Terminal on the back of the alternator, I get just slightly higher (by maybe half a volt), but still never over 13V. More like 12.5V
Questions:
1.) Did I fry the alternator diode trio when I f-ed up and blew the fusible link?
2.) Did I blow ANOTHER fusible link? I know the wire that connects to the back of the Alternator is a fusible link, but it looks OK, and doesn't seem melted...
3.) Is the alternator not getting the "charge" signal from the brown wire into the Alternator?
I am fine with returning the alternator and getting another one (I am now a professional alternator changer!), but I am worried that I have some other isse.
Or am I just now paranoid, and my truck is fine?
I will get folks pictures and readings of anything that might help.
Thanks for any help! I am supposed to go wheeling for 4 days in Shaver lake tomorrow afternoon, and I don't want to be watching my VOLT gauge the whole time...
-Dan
OK,
Here's what I know:
Questions:
-Dan
Despite the fact that this has turned into a blog about me working on my truck, I'll post again. In another post, someone recommended that I try this, so I did. Trying to get all the info I can!
(year and 3 months). At $189 a piece they are a complete waste of money. I refuse to buy another one. I bought a Duralast Gold 3 years ago and its still running like a champ.
