If you are going to assemble the pistons yourself, I recommend a floating piston. The other style has to be pressed, which if not done correctly, can result in a broken piston. The floating pistons use something similiar to a snap ring, but it isn't called that. And I can't remember the name of them either. Anyways, the floating pistons assembly would be the easiest.
