At what speed do BBs...
desertrat67
Hawk Driver
Dumfries, VA
start balancing. I don't want to throw them in the tires if the only start balancing above 45 which is past where my death wobble is kicking in.
As for the DW, I attest it to the balancing because it didn't happen before I did a tire rotation and put my balanced tires on the back.
The tires are 39.5" Iroks. I know the rotational speed of the tire will also play a part in this. So bigger tire would require higher speed before reaching the same rpm as a 35 or 37 inch tire creating the necessary cetrifugal force required to pin he BBs to the outer edge of the tire.
I have no scientific data but once I am going faster than about 10 mph they do not rattle around anymore so that would lead me to believe they are "in orbit" doing there thing.
I too had no death wobble after I used them
Dik
