Ok since the truck is running and driving I decided to start tackling some projects that Ive been putting off for years. Also hopefully to get things done in time for Overland Expo West which is coming up in a few weeks. I still need to pull the t-case and reseal it but Im still mad enough about it leaking in the first place that Im just letting is drip on the ground for a little while longer.
First up is the rear bumper. Ive been meaning to replace the crooked, chrome stock bumper since the day I bought this truck for the first time back in 2020. Ive been itching to really put the new welder to work and last week I did just that. I had previously purchased a latch and hinge setup from 4XInnovations for this project and was glad I kept it because it worked perfectly. I used 1/4" plate for the frame plates and 3/16" everywhere else. I think it turned out great!
The tire carrier mount is 1/4" wall 2x3 and the base of the swing is 1/4" wall 2x4. The extra structure on the swing is intended to mount jerry cans and a folding table. Its WAY overkill 1/4" wall 2x2 but I had it laying around so I just used it. The swing wound up weighing more than the bumper hahaha. The extra receiver on the swing is for a bike rack. I have a similar setup on my tacoma and it works perfectly so I had to do it again.
The 4XInnovations hinge and latch are super beefy and use spring loaded pins to hold it in a variety of open and closed positions.
I added some internal bracing for the receiver and welded all around it. I dont think Ill every tow anything, the truck isnt wired for a trailer, but Ill use it as a recovery point. Everything is welded on both sides. The "outside" of the bumper is welded and then ground smooth so it looks nice. My welds arent pretty enough to leave alone hahaha. The "inside" is fully welded and the hitch and frame plates are welded on both sides as well. There are currently 4, 1/2" holes per frame plate for mounting. 2 of them are existing holes in the frame that I was able to reuse. 2 are new. I cut off the bottom ~2" of the frame horns and boxed the frame in with the bumper for extra strength. I also have the option to use the 2 mounting holes on each frame horn if I decide to bump up to 6 mounting holes per side.
Anyone familiar with a K5 Blazer frame will see where I cut off the bottom portion of the horn.
I added 1/4" plate to shore it up once I decided on the shape of the bumper.
Then I started boxing everything in.
