Put together a flat tow setup to see if my RV will be able to tow the Blazer. Spent ten days driving from Flagstaff to Durango, Silverton, Ouray, Telluride and back to Flagstaff using the RV as a home base either parked at an RV park or wild camped and then used the Blazer to drive around town, go on adventures etc. Pretty stoked about this new setup. Going up the higher passes gets pretty slow at times ~30mph for the steepest grades above 10k feet but highway and normal two lane driving 65mph is easy. The attention it gets is off the charts. Individually these rigs are eye-catching but towing a camper with a camper is a whole new level. Driving across the reservation from Cortez CO to Kayenta AZ there were gnarly storms and a 30-40mph headwind. Hand calculated MPG over the 120 mile stretch was 4.13!! Thats a new record!!
Here is a picture of the setup. Tow bar is a Roadmaster Flacon 2. This is a cool tow bar because it doesnt use a standard hitch with a ball. It directly mounts inside your receiver and has a pivot and swivel to get the flexibility it needs. This is essential for the type of offroad driving I do when seeking out remote camp spots etc. The only downside to this setup is all of the pieces involved have play and when you add up the drop receiver, brake, tow bar and d-ring adaptors there is enough play that the towed vehicle moves around quite a bit.
Roadmaster Falcon swivel.
For brakes I went with a Readybrake system from NSA RV. Its 100% mechanical and there are very minimal failure possibilities. There is spring loaded mechanism inside the silver sleeve that pushes forward when the towing vehicles momentum slows enough for the towed vehicle to push forward. This mechanism pushes the black lever on top which tugs on a cable that is attached to the towed vehicles brake pedal. My blazer happened to already have a hole in the firewall immediately behind the brake pedal so running the cable/housing to the front of the truck was super easy. The whole system is incredibly basic and just works. Its so much better than the alternatives like a huge box that you put in front of the drivers seat that pushes on the brake pedal, needs to be moved/stored every time you want to drive the towed vehicle, needs power to run and relies on sensors inside the box to know when to push on the pedal.
I used a basic set of magnetic tail/brake lights that plug into the 4 pin harness on the RV and stuck them on the back bumper of the Blazer.
If I decide to tow the Blazer more frequently I will definitely make some changes to this setup so the towed vehicle settles down. Ill swap the tow bar for one from NSA that has their ReadyBrake integrated. This will eliminate one link in the chain that causes sway. Also whenever I get around to building the front bumper for the Blazer Im going to integrate D-ring mounts that are high enough so I can ditch the 4" drop receiver. This will eliminate another link in the chain. Lastly I want to figure out how to wire the stock Blazer tail/brake lights so I can plug them into the 4 pin of the RV so I can ditch the magnetic trailer lights. In the end our trip was a success and I couldnt be happier about being able to bring both rigs on the same trip without the hassle of a trailer.
