Ok you were right about that. Tore the column apart and it had simoly rotated out of park. Got it back and the lock cylinder functions normally again. Since I have it all apart Im going to replace the lock core and ignition switch since they look really old and worn out. Still not sure thisnis going to fix the window issue though. Since the switch had power in “acc” but not in off I think the ignition switch was functioning correctly.Maybe. Another issue is the rod that goes from the lock cylinder to the switch at the bottom of the column is broke or bound up.
Or, since you converted to a manual while still having an automatic column, the shift collar on the column moved which will keep the lock cylinder from rotating. Try rotating the collar counter clockwise to put it back into the “park” position.
Forgot the 3 pedal conversion. My second thought awhile after post was double gasket oil filter.
