Attempting alternator swap ( from 10/12SI to CS130 )
dyeager535
1 ton status
Solutions
Roy, Washington
From other threads I've started, I figure I might as well start one for this. Dialup folks, I'm sorry, you'll have to wait for the pics to load, they are big.
My alternator (for various reasons) is dead. Easy never being the route I choose, instead of replacing the 78 amp 12SI with another, I am going to attempt to go to a 105 amp CS130. Of course, this can not happen when I have the time to wait on the recommended parts, I have "special ordered" this one from Schucks (Checker or Kragen depending on part of country) http://www.partsamerica.com/Product...TR&MfrPartNumber=A1341511&PartType=11&PTSet=A ($89.99) it is an autolite A1341511, with a lifetime warranty. Supposedly for an '87 Camaro, we shall see. :) Part number not "correct" because the alternator is clocked wrong to accept the lower alternator bolt spacer that bolts to the case. Unbolt the three case bolts (1/4" socket works), separate the case halves just enough to rotate to where you need it, and bolt back together. You'll need to clearance the alternator spacer a fair bit as it hits the alternator case. I had to use a thick washer between the case and the bracket, bracket is just a hair off in that dimension.
In my case I've got a bunch of things going against this swap, so much of this will not apply to anyone considering a similar swap. However, the wiring and overall fitment should help some.
My drivetrain is a conglomeration from various vehicles. Pertinent in this case is the TPI, as it affects upper alternator bracket/fitment, and the 1985 Monte SS donor pulleys, etc., as that affects belts...it's the semi-serpentine 5 groove setup....serpentine for alternator, water pump, and crank, power steering on a V-belt. I am most worried about the pulley alignment...it's already not perfect, since the upper alternator bracket is for a CS130, with a 12SI forced into it.
Reason I'm going with the CS130 vs. 144 or other is because that's what my TPI came with, so it SHOULD fit the upper bracket. Not to mention that it's also in my Camaro manuals, so I have the right info for later.
For wiring, the 12SI (at least mine) has a total of 3 wires. 2 on a single plug, and one to the stud on the back of the alternator.
Easy stuff: CS130 requires two wires. One for the battery, one for a battery light, or something to provide resistance on that terminal...easiest way is with an adapter plug. Adapter plug connects your stock 2 wire 10/12SI connector (flat plug) to the CS-style alternator plug, which is 4 wire, of which 4, only one is necessary.
Adapter plug is available, without a charge light (as in my case) you need an adapter harness with a resistor built in. This is Echlin Part number (Napa) EC82. Apparently AC Delco, Autozone, nor Checker/Schucks/Kragen can cross reference this part. The part numbers normally mentioned Delco P/N 8078 General Motors P/N12102921 appear to no longer be valid, none of the above listed could cross them, they don't show up on AC Delco.com, gmpartsdirect.com, nor can my local GM parts counter find or cross them. Carquest was, and they put one aside for me. I'll post up what number they are using, when I verify it is the correct item tonight. Carquest S792 "connector".
One thing that I see being mentioned in some articles and the service manual is how to disconnect and reconnect the alternator correctly. I am going to have to remind myself of this when doing so.
Articles below are what got me started:
http://oljeep.com/gw/alt/Alternator_Theory.html#Section_3 (pretty commonly mirrored, same dates on all that I've seen)
http://www.novaresource.org/alternator.htm Nice due to the pictures of the install.
http://www.ifsja.org/forums/vb/showthread.php?t=3092 CS144 install, but a fair bit of good info nonetheless.
http://cache.search.yahoo-ht2.akadns.net/search/cache?ei=UTF-8&p=12si+swap+to+cs130&fr=yfp-t-305&u=www.binderbulletin.org/forums/showthread.php%3Fp%3D514812&w=12si+swap+cs130&d=dogrAy72RF1_&icp=1&.intl=us Cached forum thread, not sure if that will link ok. I better save it, looks like the site might be dead.
All done.
Some photos here, just didn't take one of it installed. Can if requested.
http://rides.webshots.com/album/564090900QKgBCV?vhost=rides
edit:
Be careful with the adapter harnesses.
Engagement of the terminals in the adapter plug/harness listed above that mate up to the stock alternator plug are minimal at best. No time to play around with it, but looks like the adapter plug is not necessarily designed for the truck alternator plug. It locks into the adapter, but COULD, if designed a bit differently, go in another 1/4-1/2". I'm going to figure a way to make sure the connection is good before I blame the connector.
Thought I lost my alternator the 24th (I tested it three different times with multimeter while it was on the truck, 11V with the truck running at the battery and alternator) but passed the in-store test a bunch of times.
I will clarify that I've got a somewhat odd alternator plug, although it was factory from some GM product of the 80's, might have been a van. It has almost a "t-handle" that both keeps the wires from being stressed, and allows for easier grip to pull it. I'm going to try and find a "normal" plug and see if they will seat deeper, but I don't think so, since the alternators all had the same attachment method. Only way to fix this would appear to be cutting some plastic back on the adapter harness plug AND the alternator plug, both of which is going to weaken how the two connectors lock together. I'll take pics if I can.
Here are the pictures showing the adapter harness that didn't work right, the fix, and some data.
This is the adapter harness plug mated to the stock alt plug. Note that you can clearly see the blades are not going very far into the stock plug. It appears this harness is not made for these plugs, although it fits. But this is why I lost charge. The connection was intermittent. That is unacceptable. Get a stock CS alt plug from the wrecking yard, and ad the resistor yourself. It is NOT worth the harness $$ or the potential headache! I paid about $25 for this harness that isn't correct! Anybody that can cut and splice can make this themselves. If you get an adapter that looks like this, you are going to have to cut and solder anyways, why not make the thing for about $2 instead of paying someone else (too much) for the privilege of modifying something they made wrong. In the end, I ended up cutting the 12SI plug off, the adapter end off of the harness, and soldering the CS plug directly to the truck harness. It couldn't have been easier.
Here is the pinout of the CS alt plug. You only need those two wires. On my setup the red goes to red, the yellow goes to the brown. Yellow hot with the key on, red hot all the time.
Picture of the resistor in the harness. Looks to me like they heated the shrinkwrap up too much when they made it, no sign of abrasion.
I'm not that good with the meter, but I did test resistance on the yellow wire through the resistor, which will give our electrical experts enough I'm sure to recommend the right resistor. I'm pretty sure the correct resistor value is given elsewhere online (probably in the links above) though to build your own.
Here's the stock alt plug I had originally, I think I got it from a van.
Going to have to wait on someone else to answer that I think...I would assume the connectors are the same, but I wouldn't spend money on it first.
I can take a pic of the alternator end of the EC82 I *think*, and if someone's got a pic of the 144 alternator connector we could compare.
i wouldnt wast time with cs130. to small and heat up more. dont last as long. has smaller bearings and smaller fan for cooling.
i am getting prices around to convert my cs130 to cs144 old style alt with newer front nose to fit my serp belt setup.
basicly its a 96-up optional alt for c/k truck with 350. will bolt in with super tiny mod. need to make 1 hole bigger in alt bracket position.
if me on vbelt setup i would do the '94 Pontiac Trans-Sport with rear AC mod at 140 std output.
but this is my opinion for my basic needs. and info i have found from others life experinces on this.
I believe you allude to the point...running a 130 at high load will probably shorten their life span compared to the same load on a 144. If you need a lot, then there is no reason not to go with the 144. Since the 130 was standard later on for the trucks, one advantage is it should be a bolt on with the right bracketry.
Interestingly, I believe it's the service manual that says the CS-130's aren't serviceable lol.
Whether it's a 130 or 144, it is a VAST improvement over the SI series....turning on all the accessories, or using the rear window, and watching the volt meter stay constant is very satisfying.
Bringing this back up to the top for anyone that's used an adapter harness...last half of the first post has been updated to show the "bad" adapter harness that caused me to think my alternator was bad. If you've used similar, might want to re-think it.
So I have an 88 Burb. According to your info in all the post links, I would have a CS130 alternator? I found some upgraded 130's but need to know if they are drop in for my setup. Thanks.
According to my *'91* truck manual, either the CS130 or 144 were available. Should be able to tell by the pictures which you've got, correct?
The plug will at least tell you if it's a CS series or 10/12SI...10/12SI plug is a rectangular, old tech plug (first pic above, the one on the right) , the newer one is kind of kidney shaped if looked at from the back, and has sealing material around each wire as it goes into the plug.
I didn't spend a long time getting smart on the 144, since I wasn't going to use it, but here is a picture of one apparently. Fan on the front of the case is completely different than a 130:
http://www.ifsja.org/forums/vb/showpost.php?p=23874&postcount=7
Thanks guys! Like I said I found some upgraded 130's at Summit. My wifes Burb is getting some additional doodads and I want to make sure that the stock alt isnt going to get fried as this is our tow vehicle for the travel trailer.
I think I'd stay away from the 130's if the price difference for a 144 is negligible. The 130's aren't as durable as the 144's from the get go, and increasing the 130's output is probably not as good an idea as simply going with a 144.
Not saying there is anything inherently wrong with the 130. As with anything else, you can run a 130 hard, or you can run a 144 and not tax it at all in the same circumstances.
I went with the 130 because I don't intend to ever need more than 100amps, I just needed something to bolt in, and do a better job of regulating the voltage, which it does. If I was unsure, I'd go with a 144.
same plug from 130 to 144.
and my truck was older 10/12 style before. i cut a stock plug at the junk yard. spliced it in my truck and was done no mods to wiring needed. this was when i swaped to the full serpbelt stuff with the 130 style.
next week my new 144 200a will be here and will bolt in and let you know.
I think I might run an ammeter to see how much is being drawn at full load. If I can find some deals on a 144, I'll go that route, otherwise I'll stick with the 130's I've found already.
http://shop.oreillyauto.com/ProductDetail.aspx?MfrCode=AGA&MfrPartNumber=811243&PartType=11&PTSet=A
140 amp CS144, and I believe that's the one everyone says to get. (I mean the application...1992 Trans Sport w/3.8L). $115.
For others reference, here's another article dealing with the swap:
http://www.montecarloss.com/community/ubbthreads.php?ubb=showflat&Number=493219
My stock alt plug didn't go anywhere near that deep into the adapter harness, even if it did I can't recommend the adapter harnesses for the price/ease of making your own/complexity issues.
