After seeing data in Tuner Pro RT I replaced a few things. CTS, and MAP. Now it idles nice and smooth but falls on its face when you give it the go pedal. Sputters backfires a bit. I logged a run and was watching it, it went into closed loop and idled great.
Things I have questions about:
spark advance - Should this change with RPM and not randomly go up to 100 then back down to 0 and start climbing again?
BPW?
BLM?
Unless its a bug in tuner pro i'm guessing my ESC is bad. I may do a log with the timing connector unplugged. Engine is set to 0Degrees idles perfect just falls flat when you give it gas.
it wont let me upload the log but I can send it to you if needed.
BPW?
BLM?
