hey guys, i went to install my 1.75x8" hydro-assist ram for my reverse hi-steer on my d60 and realized that there is only 6" of steering travel, so my 8" ram will not work. what size rams are you guys using with hi-steer? (should be the same as my reverse hi-steer). are you guys getting 8" of travel like you would with the tie-rod in the stock location, or does hi-steer reduce your steering travel?
at least i know its something weird going on with my setup. ill get ahold of PSC and swap my 8" for a 6"
