attn: what rpm's are ya'll runnin with your TH400's
01maroonz71
Palmetto, fl
basically im wondering around what stock would be at cruising speed on the highway, im going on a 700mile round trip journey at the end of next month and need to know how bad my MPG is gonna be...haha, im not sure what gears i got since i bought the truck as it sits, but with my 38's and my TH400...
i'm doin 2400RPM at 70mph, which is alot....
i may look into a gear vendors o/d....somebody locally is selling one....
anyways, what do ya'll run at???? thankss!!!!
hopefully some stockers will chime in.
A TH400 has a 1:1 final ratio like everything else that doesn't have OD. If you are spinning 2400rpm at 70mph then you have a 3.88:1 ratio according to 4lo.com's calculator. Since that isn't a standard ratio, I'd bet you have 3.73:1 gears. You can cruise at 70 all day long spinning only 2400rpms.
Count your blessings.....at 70mph. I'm spinning 3500rpms.:doah: :D
damn, so maybe my mpg won't be so bad at all.....hmmm....wish i had more low end grunt though...i geuss i only get one or the other
Ideal, just getting into the sweet spot on the torque band.
x2 2400 rpms is the sweet spot. great mileage/ power (well not great, but as good as it gets:p:)
10-4...i think im prolly gonn leave the gears then...since i have a pretty wild cam that give me awesome low end power...i used 4hi the other day and it did awesome....no need for 4lo at all....i geuss i do kinda have the best of both worlds. well, ill let ya'll know what my mileage will be...hopefully 12or better. i have noticed more MPG since my e-fan install....which is o.k. with me.
235/85r16's with 4.56's and 489 engine in my dually. According to my engine scanner I am doing 3100 RPMS at 60 MPH and I get a whopping 3-4 mpg on a good day.
01maroonz71 said:
10-4... i have a pretty wild cam that give me awesome low end power....
:dunno:
Wild cams are generally the ones that give top-end power at the expense of low-end torque.
What sort of cam specs are you talking about here??
well, greg...i must clear this up, im not sure the specs on the cam, but it lopes something fierce, and i've got plenty of power from about 1500 up, so i call that "low end" maybe that's mid range or so...but where i go muddin, it does me fine. wish i new the specs on the cam, but i don't. just know that it sounds AMAZING!!!! haha :)
