auburn pro series limited slip lube
motorheadnelson
Fort Mohave AZ
Was wondering what guys have good luck with. I used Valvoline dino gear lube with GM modifier. Starting to get noisy, 12K. Any suggestions? Thanks
That is what I was told to run when I had a Auburn LS. Gear oil with 1 bottle or GM LS modifier fluid.
Harley
Amsoil synthetic gear oil. Check to make sure, but I don't think you'll need friction modifier if you use Amsoil.
P.S. When you changed your gear lube did you use a solvent to flush the diff? If so, and some solvent was left in there it would break down the new lube prematurely. I only flush with new gear lube.
I have an Auburn Limited slip in my Z71 and it started to get noisey so I changed the oil and that quieted it back down. I used the oil that they had a dealership parts department. One bottle of gear oil to one bottle of GM limited slip oil.
