I have searched the forums and most of the threads on this subject are old and the pictures no longer work. I have an '85 K20 Suburban with stock axles and the auto hubs, 8 lug 10 bolt. The passenger side hub is ticking and I happen to have a set of locking hubs from an M1009 CUCV (1/2 ton blazer 10 bolt). The CUCV hubs were easy to pull and about the most fun I have had pulling parts in a while. I pulled the auto hub on the Suburban and the manual hubs won't seat far enough in to put the axle snap ring in place. I watched one video where a guy pulled an axle nut then swapped in the manual hubs, is this correct? Or are the 6 and 8 lug 10 bolts different and I need a different set of manual hubs? Any help is appreciated.
Gage
Gage
