In the middle of swapping in factory pedal assembly from an 86 k10 with manual trans into my 89 k5. I have the column and old pedal assembly out. When I put the manual pedals in the rod to the brake master is angled down to connect to the pedal pin. There is another hole that would straighten it out but looks like the mounting pin is pressed in? Also if I leave all the stock wiring in the column will it have to stay in park to start? Any pics of manual pedal installed and the angle of the pushrod to the brake master would be great. Internet couldnt really find any
