carpeonnel
I recently converted my 89 with 700/241 to 465/205 and I'm having a problem with the wiring to get it to run. I'm told I need to bypass the park wires so it'll crank but I don't know which wires are the correct ones underneath the steering column.I thought these were the correct wires and I cut the top 2 in the picture and tied them together, but that's not them. Anybody know the correct wires?
so I think I got the right wires. Found the 2 plugs at the base of the column and the yellow/ black wires do the back up lights. So I assume blueish/purpleish and yellowish/orangish are the park neutral. The plug-ins are on the top left of the steering column at the base.
(Damn tropical storm). BUT anyway I haven't moved any wires that I know of and it almost feels like it's a bad ground. If been going around wiggling wires and checking bolts, but to no avail just yet. I thought those might be the wires but from what everybody said they're in a plug-in. The starter is the only wires I haven't checked. Maybe that's it
you were right BigBlock72. I checked the starter wires and evidently I caught a couple wires in between the bellhousing of the 465 and the engine block when I bolted it up. Both of them were all chewed up when I finally got them out. Cut one and heat shrinked it and taped up the other one. Went to crank the truck and it started up like a charm
