Auto to Stick
JOES89K5
Hello members looking to do the auto to stick swap in my 89 blazer. I found a 1985 Chevy K 25 with the 4 speed setup. Will this be a clean swap from this truck ?? Thanks for any info.
85 should be a hydraulic clutch set up. Snag all the parts you can. Pedal master slave bell housing whole 9 yards. Trans will bolt up to the engine just fine as long as it's a chevy engine in both trucks. Only thing you may run into is transfer case depending on what both trucks have...spline count adapter ect.
I have been stalled The guy sold truck. But the search continues. Thanks for advise
