Auto vs manual Hydroboost setups
Ducshak
Registered Member
Idaho
I was wondering if there is any difference between auto and manual hydroboost setups? Basically would auto hydroboost systems work with pedals from manual hydroboost system? Thanks.
hydroboost unit on my 79k30 started life as stick mech clutch . then went hydro clutch conversion . and is now been doing great for years as a auto trans setup .
so nope it dosnt care to much at all.
hydroboost unit on my 79k30 started life as stick mech clutch . then went hydro clutch conversion . and is not been doing great for years as a auto trans setup .
Ditto. The pedal geometry is the same, so the booster doesn't care.
I swapped the auto hydroboost from my diesel K5 to the manual K30 no problem
