andyblack
Registered Loser
Now that there's finally some cooler weather happening, I've noticed that my engine just doesn't want to run at all when the choke is supposed to be on, like before the engine is warm. It starts up just fine and acts like it's going to run okay, but when I get on and off the gas a couple of times (like through one or two stop/go cycles), it just doesn't want to idle and I have to give it a good bit of throttle to keep it going. It blows a lot of "gas smoke" during this time. Once the engine gets to 180* or whatever it's normal operating temp is, it runs about like normal.
I suspected the automatic choke was the culprit. Before starting the engine, I could see that the butterfly for the choke (the small one in the front of the carb) was about half open and didn't seem to have much tension on it. I tightened the spring on the side of the carb so that the butterfly stayed closed and had a good bit of tension before the engine was started. I then proceeded to drive the truck to work this morning while it was 21* and it still ran terrible, just like before - no change at all.
Do I need to get the enigine warmed back up and check to see if the choke butterfly is open all the way? Could it be now staying closed for too long? Also I noticed a vacuum motor thing with linkage that's connected to the choke. How do I check to see if it's working properly?
These carbs...
This is a stock '85 305 with a stock Quadrajet and automatic choke (49 state model). It has one ground wire on the choke spring case and one electrical connector on the side. Not sure what it does.
Help would be appreciated.
These carbs...
I always thought it was a stupid idea in theory (even though it seems to work fine) because the engine might take more or less time to heat up based on whether it's idling or being driven, but the electric choke is more or less independent of engine temp.
