Magikal
So, to confirm. Obtain flywheel and pilot bearing for the 454 year/model and clutch kit for year of the sm465? Seems I remember reading about some issue with pilot bearing in these engines converting from an automatic???
I should add that the example above isn't hypothetical. I accidentally ordered a 2005 pilot bearing to go with my 2005 NV3500 clutch slave. And then turned around and ordered another pilot bearing that fits my actual 1986-series flywheel.![]()
moments during our builds...I know I've had my share of moments of opening up a freshly ordered part and realizing it's wrong...such is life, hahahaha, we've all had our share ofmoments during our builds...I know I've had my share of moments of opening up a freshly ordered part and realizing it's wrong...such is life, haha
On an older K5 I converted to a SM465, (a '72)--you could bolt up either an 11" or 12" clutch to the flywheel,but I had the old style cast iron bell housing ,so both fit without clearance issues--on the later aluminum bell housings there may be ones that only accept an 11" clutch,and another version for the 12" clutch..not sure about anything later than 87 or so,I only have had older trucks..
