WA Automatic transmission inspection covers
kennyw
@squarebody.chop.shop on IG
Stevens Pass Highway, WA
Would you happen to still have a cast 4X4 (for a 2 piece rear seal)one still available? I’m next door in Idaho.
Automatic transmission inspection covers. They fit TH350, TH400, 700R4, 4L60E, and 4L80E. There are two designs for 2-piece rear main or 1-piece rear main seals. The 1-piece rear main seal version has a larger cut out and is backwards compatible.
2wd tin covers $10 each (2X 2-piece, 1X 2- piece)
4x4 cast aluminum covers $25 each (2X each style)
4x4 Cover bolt set $10
Do you have the 4x4 version?
I have a couple, which one do you need?
I believe it's 1 piece.
I'm not a mechanic & very uniformed. I think you replied on my other thread.
I just bought the truck 85 700R 4x4.
Based on the input there is think it's a 1 piece.
I have this one i can sell. $40 plus shipping. I would need your zip code to check on shipping.
