Ok, for those of you who have installed aftermarket gauges (electric gauges in particular) did you wire them through the original cluster plug or run all new wiring? I would think it would be alot easier to tie them into the original cluster plug with the exception of the oil pressure gauge on vehicles that use the combination oil pressure switch that also acts as a back up for the fuel pump relay in which case running that wire seperate would make sense.
