TDS-MN
Registered Member
Hey All, especially those of you that are also living in the colder areas,
I've been wanting to add an auxiliary heater / block heater to the truck, since it parks outside and gets plenty cold sometimes.
There are so many options out there. Freeze-plug heaters, in-line radiator hose heaters and circulation pump heaters that will warm the anti-freeze. Also dipstick heaters, and magnet-mount heaters that you can attach to the outside of the oil pan to heat the oil.
Who's got experience with the various types and has opinions on the pros and cons of each?
I had a circulation type on an old Suburban I had for a couple years. Would warm the antifreeze and also had a small pump to circulate the heated fluid thru the coolant passages, when it was plugged into the 120V AC at home. One plus of this one was, there was some heat right away, did not have to wait for the engine temp to come up for long.
My thoughts are that the warm antifreeze circulating thru the block also kept the oil somewhat warm, because that truck never struggled to turn over even when it was well below 0deg.
I've had a few cars that had the factory-installed block heaters, guessing they were just freeze-plug style. I have not yet tried the ones that focus heat on the oil/pan.
Noticed a local store had ALL of their varieties on sale this week. Would be a good time to make the purchase, but would like to know if I'm choosing the best option or not. Looking forward to hearing yoru thoughts.
. Simple and easy to install. The cords are replacable as well.
