Vombrown
Mountain Man
here's some background. My k-20 is getting an LS engine. It's also getting a rear facing PTO. Now then, it's currently setup with saddle tanks that are going to severely limit dragging the frame over things should the need arise. Also the service bed I am planning to use make them a no-go. Now I can't put it in the back of the frame as that is where the winch will reside. So I have done some searching and I found an aux. tank that is the exact dimensions of the width of the bed inside. Since it is a new tank, I am thinking I can pull the front wall of the service bed, weld in the 100 gallon tank and rock on with my other business. The tank I am looking at will be top filling but has two threaded bungs on the bottom for fuel lines. It also have a fixture for a level sending unit. For PC the tank is 1/8" wall thickness and DOT rated to haul fuel.
Anything I am missing?
