I was out in the garage cleaning a milling vise and stumbled across a cool trick I though I'd share. Some may have already seen or known this little trick, but I bet most have not. I had an almost empty can of carb cleaner with the red straw in the tip, and a new can ready to go.
I used up the old can and went to pull the straw out of the tip and pulled the tip and all of and didn't even realize it till I let go of the straw after installing it into the new can's tip. Then of course I saw it. Then I thought, hay I wonder if it bill spray out the tip, it should I figured. Of ocurse, it did.
So you have a 360deg, completely variable to ANY angle, right angle spray nozzel.
. Bad ass! I thought that was a cool little trick I came across, thought I'd share. Use it, enjoy!
, so not to forget this I went and got the camera and took a picture so I wouldn't forget it. Freakin brain tumors
