elks
Ok so I am a little confused. I know that they used the dana 44 in both 1/2 ton and 3/4 ton applications. In the 3/4 ton I believe they are all 8 lugs and in the 1/2 ton they are usually 6 lugs. 1. Is this correct? If so is that the only difference between the 2? 2. If not what is the advantage to the 3/4 ton 44?
3. Can a 6 lug 44 be made into an 8 lug easily? If so how?
4. I already have a 14 bolt rear end, but it is out of a van. they are wider? If so how? Is it just in the hub? 5. Can I get a front spacer to make both the same width? It is for a crawler buggy so a little extra width is not too bad.
thanks for the help. I really just wish I could get a 60 and be done with it.
