seanmballesteros
Newbie
does anyone the stock ratio of 10 bolts in an 87 k5
vortec said:maybe he's like me and has no rpo code sticker in the box.![]()
seanmballesteros said:does anyone the stock ratio of 10 bolts in an 87 k5
??? wheel well???Redwookie said:Then check your inner wheel well. If not open it and count the teeth.
chevy wrangler said:??? wheel well???
chevy wrangler said:which one?
just a tip if its not a posi u can only jack one wheel up and turn it two full turns to get the correct ratio.vortec said:nobody has mentioned the ghetto method, yet. just put the rear on jackstands, put the tranny in neutral, and turn the driveshaft until the tire makes one full revolution. count how many times the shaft went all the way around and that's your approximate ratio. it's not perfectly accurate, but 3.08 will be about 3 turns. 3.42 is about 3 and a half turns, etc. do it a few times and sort of average it out.
