tumbleweed1002
who makes the strongest 10b rear axle shafts?
for the money you will spend on HD shafts for a 10 bolt you might as well convert. I know thats not what you were looking for but even with HD shafts a 10 bolt is still a C-clip axle. You can buy shafts that will hold up to a certain size tire or get a 14 bolt and never think about it. I beat the ever living snot out of mine and have never had a problem.he is not lying when he says that...gmc4cw said:GM did but they are found in a 14 bolt full floater.for the money you will spend on HD shafts for a 10 bolt you might as well convert. I know thats not what you were looking for but even with HD shafts a 10 bolt is still a C-clip axle. You can buy shafts that will hold up to a certain size tire or get a 14 bolt and never think about it. I beat the ever living snot out of mine and have never had a problem.
boz42 said:I don't know who makes the best 10b axle but if you go that route the "C" clips can be replaced w/ an elimintor kit.
I would prolly buy Yukon or Superior, depending on how much $ you were willing to spend.
Hossbaby50 said:I would not do eliminators, carry a spare stock shaft incase you break one. From everything I have heard about eliminators they are for drag race apps & leak when you apply heavy sideloads.
Harley
