axle shim install
isaac
so i am putting in axle shims on my blazer i have a block lift set up. my question is where do the axle shims go? sounds like a dumb question but im not sure if they go in between the spring and the block. or if they go between the block and the axle spring perch? one last question do i have to bolt them to the spring or will they stay in place just like the lift block dose?
thx
isaac
Keep in mind that with any significant shim and blocks the axle will move forward more the longer the block.
