axle shim ?
Randy92782
1 ton status
Arcadia, MO
Alright. I'm gonna order the shackle flip for my 72 chevy from kert. I've never installed one of these before and am wondering (if any) what degree shims should i install to correct my pinion angle?? I would need something to compensate right??
Also what else would i need??
It should be fine not many people add one after the flip it usually sets the angle right for you. Post a pic when installed.
I think it depends if you have a factory block that you are removing. The factory blocks usually have a slight taper built in. I had to shim mine down about 4-6 degrees. Actually I cut and rewelded my spring perches.
Cool. I just went out and looked and there isn't a factory block.
Another question though. Were the 67-72's shackle brackets all bolted on??
These are and it looks to have some small ass bolts as well :eek: Just makes it easier for me when i go to change it. No griding the rivets off. I know the rear end was changed more than likely cause someone cut the e-brake cable and tied it up :doah: guess i'll have to order another of those as well. the cable that is
