Axle shims, fuel reg
MNorby
3/4 ton status
Powell, Wy
Selling a set of three 6 degree steel shims (use one above and below springs on a dana 60 to keep top plate Parallel for housing studs) Installed but never run before changing springs around. $40!!! shipped
Zero rate block drilled to allow you to move axle 1" or 1.5" and has a ~4 degree taper milled into them. $sold to TXZ
Mr. Gasket fuel pressure regulator. $12 shipped
2 sets of Poly reservoir shock mounting tabs $sold
