1BEATK5
im looking to build a dana 44hp for my xj. so it needs to be 60-62" wms.
i was thinking about 1980 and up wagoneer width with a ford 5 lug to match my rear axle.
i have a line on a 75 ford f150 axle. which is 67" wms.
then i would need a 80 and up wagoneer axle.
which would you do?
option 1 press the tubes from the waggy axle into the ford center, with the ford knuckles?
or
option 2 cut down the ford axle to axcept the waggy shafts?
im pretty sure i could cut down the ford axle myself, i just havent re-tubed somthing before and im not sure how easy it would be for me to do at home. option 2 seems easier. or atleast quicker with the proper tools
to answer your next question, i have a rear axle. its a 60-2. semifloat 30 spline, with 5 on 5.5 bolt pattern. its 60" wide stock
which would you do?
or
