axle/spring swap --will it work???
beatermule
Registered Member
belchertown ma
so i can get a full long bed 84 gmc 3/4 ton rolling chassis for 200 bucks, rebuilt front axle, 4:11 gearing front and rear, leaf springs, frame, everything but a body/motor/trans/transfercase. thinking of getting it and using the axles in my k5, just want to make sure the spring perches are the same width and that itll be a bolt in deal without needing anything too crazy. i figure the price is right so why not. anything i should know before i do this???
It should volt right in, but it never hurts to check the perch spread first. I cut up a GMC with C25 badges on it and found 1ton spacing on the rear suspension.:doah: The upside is that you could still use the other hangers if that happened to be the case, and the swap would still work.
A lot of guys will move the spring perches and shock mounts to make it work if it turns out to be a one ton axle. It should all be the same though. Don't know about the brake lines...
