axle stand. pics
rdn2blazer
1 ton status
- In Memoriam -
So Cal.
a few years ago there was this piece of tooling on wheels, kind of a cart or base, or stand of somesort sitting around our machine shop yard. it was kinda rusty and it never got used. so one day I asked my boss what was it for? he said they welded it up for a job then the job was canceled so its just been floating around for years.
so I asked if I could have it to make something out of it. he said sure. so I brought it home and made a axle stand out of it. I widened to fit just outside my spring pearches just between the pearch and flange of my crewcab 14FF. then I had to make some way to support the axle so I welded up these legs and used the "V" tops off my pipe jack stands. I even got a hair up my but and thought HAY! I will make it adjustable up and down.
so I bought 2 square "U" bolts so it would be easier to pull out, kinda like a handle, and made pins out of them to hold the legs up with different riser holes. I turned up two teflon rings for the jack screw handles to spin on, figured it would be less friction when trying to level the axle.
the problem I ran into was when I bought my blazer then got my 14FF for that truck I found out the spring pearches were obviously a different width. so the axle did not sit in the "V" well. it could not spin 360 deg without hitting a pearch since the width of the stand is fixed. so I had to add in a adjustable riser that could be adjusted side to side. I just take one V jack screws out of the stands riser leg and put it into the adjustable slider riser and position it where ever I want then tighten it down to take the movement out of it.
ok, this stand is WAY OVERKILL and completely unnecessary, BUT! EVERY PIECE of material for this stand was given to me by my boss except for the jack screws. everytime I ask do you mind if I use this he allways says use what you want, I dont care. it does work great for holding an axle to work on it. here are some pics.
I also POR 15'ed it and powder coated the handles just to see what the color looked like. more pics.
my 4 yr old took this one.
dremu said:
I respectfully submit that you change your tagline to read "Tool nerd" :haha:
-- A
LOL!:haha: :haha: :haha: OH MY GOD THATS SO TRUE!:haha: :haha: I have a 0 to 1 in mic, a 1/2 in wrench and philips screw driver in my pocket protector.
Things were looking pretty good up until that last pic, then ya had to go and mess it up... :(
Me thinks I've seen that somewhere before. That has got to be one of the most trick axle stands I've seen, and probably the most beefy too! :eek:
dude, where do you live? I wanna buy the house right next door. :thumb: Few better friends to have than a guy who has mad machining skills and lots of cool truck toys as a result. :grin: I don't even drink beer, but I'd have a full fridge if I was your neighbor. lol!!!!
j
Kinda makes my usual setup of 3 jackstands look pretty lame.
NIce work! I use a variety of stands around the shop. The longer I go the more I need to build something axle specific. Good job.
