Found out my 82 K2500 has a axle u-joint on the drivers side thats shot,after 10 years of hard plowing abuse--one cap on it has no needles left,and a chunk missing from it..have to replace it before winter or risk it blowing apart and or wearing the stub yoke out..
I had 2 Spicer 5-260X u-joints kicking around,I remember trying to install one on my other GMC and I could not get the clips on the caps,so I ended up buying others at Autozone..
One of them is new in the box un-used,and has the 4 clips--the other is missing two of the rubber seals and the clips..I tried digging thru my collection of spare clips,but most of them are too thick to fit in the grooves,and I doubt you can buy them separately..I have tons of spare outside clips.not many inside clips though..
I suppose it would be unwise to install it with two seals missing,but maybe I can re-use the ones off the original joint or use an O-ring..I know new ones aren't that expensive,I just hate not using what I already have..especially when the truck is very borderline as far as being a reliable daily driver..
Not trying to to TOO cheap,but if these u-joints will fit I figure I may as well use at least the one new one...not looking forward to this job,my brake rotors look ready to part in the center where the cooling fins are too,they are so rotted--so that'll mean another 100 bucks,provided I dont find junk wheel bearings,or other parts on the way in there...
With the oil pan being junk on this diesel,plus it having other woes like an exhaust pipe paoer thin,that I found a nice hole on ,on the passenger side today that I patched with tin and hose clamps,and rotted exhaust manifolds that probably wont let the bolts come out even with heat from a torch,I'm tempted to just give up and sell the dam thing..my back cant take lying or kneeling down for long,and I cant afford to pay anyone else to do it..I'll be lucky to get the axle joint fixed myself..
I hate finding this kind of trouble right before your going to need the truck the most to plow..
..With the oil pan being junk on this diesel,plus it having other woes like an exhaust pipe paoer thin,that I found a nice hole on ,on the passenger side today that I patched with tin and hose clamps,and rotted exhaust manifolds that probably wont let the bolts come out even with heat from a torch,I'm tempted to just give up and sell the dam thing..my back cant take lying or kneeling down for long,and I cant afford to pay anyone else to do it..I'll be lucky to get the axle joint fixed myself..
..I guess they were leftovers from my 71 GMC I had decades ago maybe..I think someone gave them to me,I cant remember..(probably didn't fit that truck either,it had disc brakes)..
..not without towing on my insurance anyway..
