xCaliK5x
So, My TSL's are going to be needing replacing soon. I was told by a friend to go up on tire size, or go with the same size and maybe take out some lift.
Also, how big of a tire can a D44 handle? I'm happy with the height its at, going down on a lift seems backasswards to me, I see having lots of options, I don't have a lot of money to spend, but do not want to skimp on **** that can leave me stranded. I will say I'm not heavy footed. I also do not have cross over steering at the moment. I don't even know if I have a dropped pitman arm.
What tire size should I run at its given lift?
Put on bigger tires and put shafts in the D44, I searched and have found confusing results from no problems at all, to "I broke 3 shafts before I put a D60 under it"
Put bigger tires on it and save money and swap in a D60. From the looks of the prices on shafts for the D44, a D60 is a little more money.
Put 36's back on and leave as is
Put 36's on it and take some lift out.
This is the only pic I have at this angle so you can see how it sits..... Thanks for your help guys.
And a shot next to my buddies bagged dually crew cab. So weird seeing a hood as high as the roof of a truck!
