TX axles
fourwheelerjeff
I spend too much time here
Staff member
Moderator
SW OK
axles for sale:
GM 10 bolt rear 6 lug with 4.10 and cracked carrier $100.00
GM 12 bolt rear 6 lug with 4.10 out of a 72 K5 $250
GM 10 bolt front 6 lug with 4.10 $300
GM 14 bolt semi float rear 6 lug missing drums and brake parts $150
GM 14 bolt semi float 8 rear lug missing 1 drum $150
GM 10 bolt front 8 lug with Dana 44 outers 4.10 with locker $350
GM Dana 44 front 8 lug already set up for high steer and crossover $500
GM 14 bolt Semi Float out of an 80s model 3/4 ton so has the spring perches and shock mounts in the right place for a square body. gear ratio is 3.73 $250
Dana 70 HD with heavy duty diff cover. has 4.10 gears. $350
Toyota front axle that to be honest looks like I got it from the bottom of the sea. has sat outside and needs taken apart, cleaned and blasted. completely stock as far as I know, got it for a truggy project that is also for sale. missing rotor and parts on left side $200
Early Bronco Dana 44 front axle that is pretty bare. I believe it has Chevy knuckles on it as they are 6 bolt instead of 5. no axle shafts. $250
lots of other axles; trying to clean up. just ask.
Wish you were closer. Shipping is murder...
