B.C. Bronco leaf spring rockers
jcoppin
Registered Member
Denver
B.C. Bronco spring rockers. add 2.5" of rear suspension lift. $125
The B.C. Spring Rocker is a pivoting spring perch that relieves the natural bind that occurs in a stock leaf spring rear when the axle housing is in articulation (out of parallel with the truck chassis).
might be interested. so the top portion are studs? how much shipped to 22039? can it use the stock spring plate? is it specifically for a 14b, or can it be used to axles with different tube diameters? thanks
I will check on the shipping for you tomorrow. The top portion is actually bolts that can be changed out of you have the need. The current bolts should work for most springs. You use the stock spring plate to hold it in place. The fit is pretty universal, and will work on most axels.
ive got a dana 70 with 4" diameter axle tubes, can you measure to see what the distance is between the mounting holes that go to the axle for the ubolts?
Yes, I will check the dimension for you tomorrow. I just checked the shipping from UPS. Standard ground shipping will run $25.
In Littleton
Saw your ad on Craigslist and emailed you. Interested in the axles if you still have them.
Interesting design. Curious about the shear strength of the pivot bolts and of course lateral stability for a trail rig.
I checked the dimension today and they will not work with a 4" dia. axel tube without modification. You would need to slot the u-bolt hole approximately 1/4" on each end. There is about 3/4" of material from the edge of the u-bolt hole to the edge of the block. So if you slot the hole you would be left with 1/2" of material from the bolt slot to the edge of the block.
In response to the question regarding shear strength; I never had any trouble with them and I did my share to abuse my rig, I have a pile of broken parts left in my wake...and this part is still like new. There were never any lateral stability issues that I could feel, the only sensation or feeling you get is that your suspension is not working so hard to flex.
yea stallion85 used to have a set similar to that. it seems to me the rear would flex alot more with those.
not that i would, but i wonder if you could run something like stat up front.
do the people that make those have a website? id like to see if they make a set for 4" tubes. otherwise i might just buy yours. any trades?
Let me know if they make them for 4" tubes. I am not interested in any trades now because I am in the process of getting out of my truck. Thanks for the offer.
